Hi! I would like to know what are the difference between
E10G42BTDA and E10G42BFSR
the first one has a cable type:
SFP+ direct attached
twin axial cabling up to 10 m
and the second one:
MMF 62.5/50 μm
up to 300 m
I need to use the E10GSFPSR. Wich one of the previously mentioned network adapter is compatible with this sfp+ module?
And what about your E10G41BFSR?
Thank you.
Kaiyu
Check out the compatibility tables listed at http://www.intel.com/support/network/adapter/pro100/sb/cs-030612.htm Intel® Server Adapters — Which SFP+ modules, SFP modules, and cables can I use with the X520 Series? - that should answer most questions.
