No matter what I try when I login to my intel nas ss4000 I always end up at a page warning me about a disk change: https://192.168.0.101/raid_disks_changedF.cgi (see attached screenshot too)
I am very sure i did NOT change my disk configuration. All my leds are green. Everything seems to function normal expect that I cannot access the control panel anymore (very frustrating btw). I have tried powering down, different browsers or urls all with no result.
I am ready to take out a disk and break the raid to see what happens, but that seems a bit too hard core.
Any help is appreciated because in this state the NAS is not very useful.
Onno
have you tried the steps at http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-026151.htm yet?
Yes I did,
Does not make a difference. I only get the disk chage notification page. I have not tried to take out one disk and then start the NAS to see what happens. I am a bit reluctant to do that as i do not want to loose my data....
Hope you have more advice for me.
Thanks in advance.
Onno
The only other option I'd suggest is contacting tech support. I know there's some "x-ray" file they can have you pull and send to them, and often they can recover all the drives without a problem.
Do you resolved your problem ? because i have the same .
tanks
Hi, i have the same problème on a Nas acer Altos Easystore 2T.
The problem is that i also want to keep my datas (thousands of pictures from family, kids, hollidays..)
Thanks for any help.
Hello
I also have the same problem. Have you solve this problem ?
FB- Mark as New
