Server Products
4778 Discussions
Distribution of server power between two power supplies Intel R1208WFTYS
DASTY
Hello friends,
The servers use only one power supply to work and the other is in reserve(supply#1=90-100%;   supply#2=0-5% this is how the server uses power supplies). The server can change the use of the unit and transfer power to another. This is a problem as such a situation can put a heavy strain on power lines thus creating a critical load on 1 line when the other is not involved.
How can I change the settings for an even load on the power supplies(supply#1=50%;   supply#2=50%)?
or
How to control switching between power supplies?
In servers the balance of mod is chosen.
Victor_G_Intel
Hello DASTY,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
AdrianM_Intel
Hello DASTY,
Thank you for your patience.
After investigating the server configuration, we would like to share with you the following information:
The server system can have up to two power supply modules installed and can support the following power supply configurations:
  • 1+0 (single power supply)
  • 1+1 redundant power
  • 2+0 combined power (nonredundant)
1+1 redundant power and 2+0 combined power configurations are automatically configured depending on the total power draw of the system, If the total system power draw exceeds the power capacity of a single power supply module, power from the second power supply module is utilized.
For more details you can check the following article:
https://www.intel.com/content/www/us/en/support/articles/000087933/server-products/server-chassis.html
You can also check the power configuration details on the R1000WF TPS Page 29 section 3.1:
https://www.intel.com/content/dam/support/us/en/documents/server-products/IntelServerSystemR1000WF_TPS_R1_0.pdf
Since the power configurations are automatically configured, the server will balance the load of the PSUs however if you want to set up any of the configurations above you can check on the following article steps:
https://www.intel.com/content/www/us/en/support/articles/000025905/server-products/server-boards.html
It is worth mentioning that 2+0 combined is nonredundant as a single power supply.
I hope this helps.
Let us know if you have any questions.
Adrian M.
AdrianM_Intel
Hello DASTY,
Let me know if you need more assistance.
Adrian M.
AdrianM_Intel
Hello DASTY,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
