Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4811 Discussions
Does Intel integrated Raid RMS2AF040 support more than one Raid 1 array
CSlad
I have a server with Intel integrated Raid RMS2AF040 that is configured for RAID 1 array with 2 SAS drives. I added 2 sata drives that are recognized by the controller. the question is can i create a second raid 1 array? if so what are the steps?
thanks
CS
Edward_Z_Intel
Yes you can. You can add a second VD using either RAID BIOS console or RAID Web Console 2. For more details, see the http://www.intel.com/support/motherboards/server/sb/CS-022358.htm Intel® RAID Software user's guide.
Edward_Z_Intel
CSlad
thanks edward, i figured out how to do this via the web console. I was just being dense.
you need to remove the new drives from being JBOD in the physical tab
then you need to select the logical tab
right click on the controller and select create a new virtual drive
the wiward kicks in at this point and walks you through the process
thanks again
CS
