I am planning to build up a SOHO server with a S1200BTS(R) mobo. As i don´t need much processing power a pentium CPU would be enough for me.
In the http://www.intel.com/support/motherboards/server/sb/CS-032414.htm CPU compatibility list there are listed among others G840, G850 and G620. But afaik these CPUs do not include support for ECC RAM.
On the other hand the http://download.intel.com/support/motherboards/server/s1200bt/G13326-003_S1200BT_TPS_v1_0.pdf board manual mentions ECC RAM as stringently required.
How can one operate above mentioned processors in this board with the ECC-RAM without having ECC-support in the built-in memory-controller?
Best regards
All CPUs in the http://www.intel.com/support/motherboards/server/sb/CS-032414.htm CPU compatibility list can work properly with ECC memory.
