Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Does the Intel S2600WT server line (S2600WT2R) BMC provide support for the Redfish API?
COwen5
We currently use the Intel S2600WF0 and S2600WT2R server models. We are able to use Redfish API with the S2600WF0 BMC. Also, the Firmware readme notes for the S2600WF0 include many fixes and updates related to Redfish.
However, we have not found any reference to Redfish for the S2600WT2R nor have we discovered how to enable this feature (if possible). This API is used for remote automation testing. Does the S2600WT2R have support for Redfish? Perhaps another separate module to download or feature to turn on with BMC?
Thank you,
Cullen
Emeth_O_Intel
Hi Cullen,
Thank you for contacting us about this concern.
I am checking the information about the compatibility of the API with the Intel® Server Board S2600WT2R,
I would like to request you time in order to take a deep look into this in order to provide you the most accurate information as possible.
On the other hand, I found the following document: https://www.dmtf.org/sites/default/files/RedfishForumCharter_2018-04-19.pdf. This is the Redfish Forum Charter where you will have the possibility to ask them directly this information as well meanwhile I am double checking the information on my end.
Please let me know if you will be able to contact them, as soon as possible I will get back to you with the information and the next step.
Emeth O.
Under Contract to Intel Corporation
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
COwen5
Thank you for the reply. I did check the attached document and found the Redfish Forum. It appears memberships are required and there is a free membership to gather some basic information from the community. Checking on if this server model does support Redfish, I have not yet received any replies, as the majority of their forum is about how Redfish works instead of hardware in the field that supports Redfish.
If you have acquired any information from the Intel forums or BMC teams, that would be great.
Emeth_O_Intel
Hi Cullen,
I was checking those details and I would like to let you know that all Purley and Purley R boards are compatible with redfish; however, older families such as Grantley like the S2600WT you mentioned before are not redfish compatible.
Please if you have any other question, let me know and I will be more than happy to assist you.
Emeth O.
COwen5
Thank you for the reply. I will forward this information to our automation engineers for future planning requirements of our equipment needs. You can close this ticket.
Emeth_O_Intel
Hi Cullen,
No problem, if you need more information do not hesitate and contact us back and we will be more than happy to assist you.
I will proceed and close this thread as per you request.
Have a wonderful day.
Emeth O.
