Server Products
4772 Discussions
Drive fault led??
ATsit2
Hello to all community...
I have a homemade server with this parts :
Cpu i3 560
M/b intel s3420gplc
Ram kingston kvr1333d3e9sk2/4gi 2x2gb
Raid controller srcsatawb raid 6
Disk 8x2tb wd2003fyys re4
Psu corsair hx850
Os win2008r2 standard
if a drive fault, how to know which drive fault of these drives?? the controller has 8x2 pins for drive fault led..
i searched for more technical detailes in intel site and nothing found..
can any one help??
thank you..
Edward_Z_Intel
Only if you're using a hot-swap backplane that supports drive fault LED, and you have connected the correct cable to the backplane.
ATsit2
Dear Edward.. your answer is very helpful.. now i'm serching for backplane..
the backplanes of intel.... at this http://download.intel.com/support/motherboards/server/sb/backplane_cabling_for_s5000_pedestal_systems_3_0.pdf pdf says that
Expander Backplanes:
AXX6DRV3GEXP or AXX4DRV3GEXP
SAS in-band.
No Fault LED control cable needed.
Note: Intel® RAID Controllers SRCSATAWB offers expander backplane support.
and
Non-Expander Backplanes:
AXX6DRV3G or AXX4DRV3G
RAID card connector: J6, white
Backplane connector: SES, white
Cable: 3-pin SES
Note: RAID FW 420 or higher is required.
which of these is the best solution for me to choose??
please remember that my controller has 8x2 fault drive pins.
Edward_Z_Intel
Both will work with your controller. If you use a expander backplane, you don't need any cable besides the SAS data cable. If you use a non-expander backplane, you'll need to connect the 3-pin SES cable for the drive fault LED to work properly. I believe the cable comes with the backplane. The 8x2 fault drive pins are not used with Intel backplane.
ATsit2
f i connect a hdd activity led to one of these 8x2 pins and before i boot the server i disable one or two drive/s for drive failure, i think the led start blinking?? is that true??.. or if you have something to suggest it will be more helpful for me..
Edward_Z_Intel
That 8x2 pins connector gives you 8 fault LED signals - one LED per drive. Meaning if you connect the HDD activity LED to two pins for drive 1, and then your drive 2 fails, the LED won't start blinking. LED behavior is documented in http://www.intel.com/support/motherboards/server/srcsatawb/sb/CS-028266.htm TPS section 2.7.4.1. It won't be necessary if you're using an Intel backplane.
ATsit2
and if i connect 8 leds??
if any drive from 8 that are connected on the controller faild.. that led shuld be blinking
is that correct??
Edward_Z_Intel
