Is dual CPU base system configuration is a better solution? up to what percentage output can expect of (200% Ideal?).Any affected factors to reach ideal maximum output?
Pragnesh
Hello PragneshVirani,
Thank you for joining the Intel Community Support.
It really depends on what you would like to achieve after building the system. Could you please let us know what you would like to accomplish?
Also, have you researched about any possible motherboard/processor you would like to have when building your system?
Wanner G.
Hi Wanner,
Thanks, we are planning to use for vision inspection(image processing) with multi-thread operation.
previously we used Dual Xeon E5-2667V4 with supermicro motherboard.now planning to build for similar vision inspection with Deep Learning.
Thank you!
Pragnesh
Thank you for the information.
In order to address your inquiry better, I will forward it to the proper department to provide information that may help you get the most out of the new build.
I appreciate your patience.
Wanner G.
Information on the best system to achieve the best use for Deep Learning.
The best option will be to contact a local Intel Re-Sales.
https://www.intel.com/content/www/us/en/products/find-a-reseller.html https://www.intel.com/content/www/us/en/products/find-a-reseller.html
This because you could be looking for a 2U or more bigger server. Type of memory you might want to use. And the storage if you like to use an Internal Software RAID controller, or if you want to use a Hardware RAID Card.
If there is anything else we can help please feel free to ask.
Henry A.
I just will like to follow up and verify if the information sent helped.
This other link might also help you:
https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal... https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal...
Henry A.
Hi Henry,
Thanks for the update, I was looking Processor performance.Anyway, I am planning to build single CPU(Gold 6154) with high-end GPU(1080Ti, 8G/11G series) and will try to analyse performance.
Pragnesh
