Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
E10GSFPSR datasheet
Hi! I'm looking for the
E10GSFPSR
electrical datasheet. The only one i could find is the product brief.
Kaiyu
Tags (1)
Highlighted
There is no datasheet on that adapter, only the product brief. Do you have some specific data that you need?
Mark
Highlighted
Thank you Mark! I would like to know what are the 20 pins, the voltage needed by the transceiver and any accessory signal besides the 2 differential for tx/rx.
Regards.
Highlighted
I misread the product code and didn't recognize it as the optical module until I took a second look. Most of the data is in the http://www.intel.com/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf optical module product brief. But if you need more, you can download a datasheet using the manufacturer part number on the module. The Intel modules are branded versions of modules from a couple of manufacturers.
For example, I pulled one of these modules from one of my SFP+ adapters and see a Finisar part number FTLX8571D3BCV-IT. I found the datasheet at http://www.finisar.com/sites/default/files/pdf/3TAVfFFTLX8571D3BCV%20Product%20Specification%20RevB.... http://www.finisar.com/sites/default/files/pdf/3TAVfFFTLX8571D3BCV%20Product%20Specification%20RevB..... I think you will find all the voltage information you need in there.
Mark H
Thank you Mark!
So you are actually telling me that the E10GSFPSR
is a transceiver not manufactured by Intel.
It's weird because I find that among your products.
Have any chance to check if there is any other part number written on the E10GSFPSR?
Thank you!
Regards.
