Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
E3-1275v3 P4600 Graphics
EHoly
I have this cpu installed with Server 2012 R2. I wanted to install the drivers for the p4600 graphics to just do a really basic RemoteFX run. I know it is far from optimal but still wanted to just try it out. I found a driver for the p4600 graphics here http://drivers.softpedia.com/get/GRAPHICS-BOARD/INTEL/Intel-HD-Graphics-P4600-P4700-Driver-918103222-64-bit.shtml Download Intel HD Graphics P4600/P4700 Driver 9.18.10.3222 64-bit for Windows XP 64 bit, Windows Vista 64 bit, Windows 7 64 bit, Windows 8 64 bit.
However when I went to go add the driver through device manager it only results in a Yellow bang and the device is not usable. The driver installs no problem just the graphics adapter is not fully functioning. Is there a way I can install this driver and get use out of the p4600 graphics on server 2012 r2 or am I SOL?
I appreciate any help thank you.
Edward_Z_Intel
EHoly
That worked perfectly thank you very much for that help.
