Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4552 Discussions
ESRT 2 SATA & SAS SOFTWARE RAID DRIVE
BVerd
Hi!
ESRT 2 SATA & SAS SOFTWARE RAID DRIVE how can i install on bios, since i reformat a hard drive and install a new windows server 2008, when i came to bios set up and enable the mass storage to RAID then it would'nt
work? what are the steps to install the driver ESRT 2 and RST on BIOS intel server board s1200bts? i dont have a brilliant mind to this...how can i know that the driver RAID are install on bios? how will i do to install the raid of 4 drives hitachi?
Thank you!
Edward_Z_Intel
You need to configure RAID first, and then install OS on the RAID VD. RAID driver needs to be loaded during OS installation.
The step-by-step demos below will tell you how to do that:
http://www.intel.com/support/motherboards/server/sb/CS-029508.htm Demo: Configuring Intel� Embedded Server RAID Technology II
http://www.intel.com/support/motherboards/server/sb/CS-030677.htm Demo: How to load the Intel� Embedded Server RAID driver during an OS install
BVerd
edwardzh,
Many Thanks to you sir..this will be helpful for us.
Thank you very much sir...appreciated much for your technical support.
Seann:)
