Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4303 Discussions
ESXi 6.0 installation
AYazb
Dear Sirs,
I have an intel S2600CW server board with an inyel ESRT2 Raid controller.
I am trying to install VMWare ESXi 6.0 on it and the RAID controller is not supported.
Is it supported to download the .TGZ RAID drive from intel site and add it to ESXI iso (Installation file)?
Amir Yazbeck
David_A_Intel
The onboard solution only supports the installation of ESXi in AHCI mode using the ACHI capable controller only. Currently, the ESRT2 RAID controller does not offer support for VMware Operating Systems.
http://www.intel.com/support/motherboards/server/sb/CS-033209.htm Operating System Compatibility
