I have corrupted Ethernet adapter at server board SE7505VB2. Can you give me advice which new model of Ethernet adapter (1 Gb PCI or PCI-X) I would can to buy?
- Tags:
- Adapters
Check the http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007397.htm?wapkw=(se7505vb2+tested+... Tested Hardware and Operating System List
Have you tried to reflash the board firmware bios since the bios image contains the pxe option rom for the gbe.
http://downloadmirror.intel.com/9659/eng/releasenotes.txt http://downloadmirror.intel.com/9659/eng/releasenotes.txt
Otherwise, please refer to the THOL validatic NIC adapters for this board:
http://download.intel.com/support/motherboards/server/se7505vb2/sb/se7505vb2thol.pdf http://download.intel.com/support/motherboards/server/se7505vb2/sb/se7505vb2thol.pdf
Page 16/29
All the best,
Kind Regards,
Aryan.
