Hi, i can't solve the installation of Intel(R) ICH9M-E/M SATA AHCI Controller drivers during W2003 server installation. I load drivers by a floppy (everything is ok) and when windos begon to install files on the HDD, it ask me to insert floppy named "Intel rapid storage technology driver". Any solution ?? Bests
I guess you're using a USB floppy drive, and most likely Windows installation doesn't recognize it correctly as a USB floppy. See http://support.microsoft.com/kb/916196 http://support.microsoft.com/kb/916196 for details.
You may either get a USB floppy drive in the list, or try the following workarounds:
http://www.intel.com/support/motherboards/server/sb/CS-026606.htm http://www.intel.com/support/motherboards/server/sb/CS-026606.htm
http://www.intel.com/support/motherboards/server/sb/CS-029550.htm http://www.intel.com/support/motherboards/server/sb/CS-029550.htm
