Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4724 Discussions
FR2UFAN60HSW - Fan Datasheet
pabrooks6
I'm looking for the specific, fan manufacturers datasheet for this spare assembly.  I appears to be a Nidec fan (from photos).  Can someone someone on this form help
Paul_R_Intel
Hello pabrooks6,
I hope you are doing amazing, thank you for your patience, we got the UL code for the FANs: a60E12BS1B5.
Please let us know if there is anything else that we can do for you.
Paul R.
Intel Customer Support Technician
For firmware updates and troubleshooting tips, visit:
Paul_R_Intel
Hello pabrooks6
Thank you for joining the community
Please allow me to investigate this matter and I will get back to you as soon as possible, in the meantime, can you please tell me in which system you are using this fan and the reason why you need the datasheet?
Paul R.
pabrooks6
We are working with an L9 configuration based upon the R2224WFTZS.
There is a requirement for Import purposes.  I can provide more details if require (other than public forum).
p
Paul_R_Intel
Hello pabrooks6,
I hope you are doing great, thank you for your patience and time, unfortunately, this document is confidential. What information do you need , to verify if we can pull it from the document?
If we do not hear from you we will follow up on December 15th.
Paul R.
pabrooks6
Hi and thanks Paul, understood.
The original requirements are for the volts and amps.  We think we found a photo online and the fan in the photo show 12v / 1.6a.  Can this be confirmed?
Also, additional requirement - the photo show the product is UL listed - can the UL listing number be provided (this is for report purposes).
Pat
Paul_R_Intel
Hello pabrooks6,
I hope you are doing great, thank you for the update, I will investigate further and I will get back to you as soon as possible.
Paul R.
Paul_R_Intel
Hello pabrooks6,
I hope you are doing great, thank you for your patience we continue to work on getting the information requested, we were able to confirmed that according to the schematics of FR2UFAN60HSW, the requirements used for its operation is 12V and 1.60A.
I will update you as soon as I get the UL number.
Paul R.
Paul_R_Intel
Hello pabrooks6,
Paul R.
Paul_R_Intel
Hello pabrooks6,
I hope you are doing great, we would like to follow up on your inquriy,
Paul R.
pabrooks6
Yes, this is the information that I was looking for.
Thank you!
