When trying to update the firmware with the content of IR3_2108SASHWR_FWPKG-v12.13.0-0154.zip on a USB stick,
it fails with:
Adapter 0: Intel (R) RAID Controller RS2BL040
Vendor ID: 0x1000, Device ID: 0x79
FW error description:
flash image was bad
Exit Code = 13
I have tried to copy the files on another USB stick, and also tried to update from Linux using Cmdtools2 with same result.
Is there a problem with the MR410p.rom file, or am I using the wrong file ?
Poul
- Tags:
- Intel® RAID RS2
I was trying to upgrade from version 2.70.03-0862 to version 2.130.373-2022 in one step.
Upgrading to version 2.120.63-1242 in first step, and then to 2.130.373-2022, it worked.
Poul
