Server Products
4778 Discussions
FreeBSD and SR1630HGP with 82578DM
Hello.
I have SR1630HGP server with 2 network adapter.
FreeBSD 7 see only 1 network card (82574L), but 82578DM is not.
I download and install http://downloadcenter.intel.com/download.aspx?url=/17509/eng/em-6.9.21.tar.gz&DwnldId=17509&lang=rus Network Adapter Gigabit Base Driver for FreeBSD* 7.x and OS see 82578DM.
But after that when i shutdown my server (shutdown -p now) - it reboot, not shutdown.
I install driver like write in README:
cd em-x.x.x
make
make install
Edit /boot/loader.conf, and add the following line:
if_em_load="YES"
Also i disable em in kernel.
I try to update to FreeeBSD 8.0 - but is steel reboot, not shutdown
PS if i disable if_em_load="YES" in loader.conf - FreeBSD shutdown OK.
Daniel_O_Intel
Generally, if an OS hasn't been tested by Intel (see http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030739.htm ), you may get unpredictable results
I can confirm that FreeBSD 8 (8.1-RELEASE) works fine on SR1630HGP.
Just make sure you include the acpi driver *in* the kernel with your amd64, or the kernel will reboot at boot.
You find an optimized kernel configuration here:
http://lists.freebsd.org/pipermail/freebsd-hardware/2010-September/006416.html
