Hi, so I'm building a deep learning machine with the P4304XXMUXX and a RTX3090. I'm encountering several challenges:
(1) Apparently S2600CW has a max. power uptake of 300W for one single card. I might have to throttle the graphics card to 300W, which is a pity but not the end of the world.
(2) The 750W-PSU doesn't provide 8-pin PCIe connectors. There is already another post addressing the same issue but the suggested solution is to use a Molex to 8-pin adapter, which forum entries and sellers explicitly warn against.
(3) What follows is the information available in the server docs (see attached files)
- The manual advises using a 2x3pin plus a 2x4pin connector to supply the required 225W in addition to the 75W supplied by the PCIe slot (screenshot 1). But it doesn't say where to connect these.
- The configuration document suggests that there might be an accessory kit including cables (screenshot 2), but it's impossible to find and is no explanation where the cables could go.
Your help as to the best way forward is much appreciated.
Thanks!
Hello KlausH,
Greetings ~
Thank you for reaching Server community support. This is to inform you that the support for the said products have been switched to self-service support.
The available self-service support options include:
Technical support content available online
Discontinued products could be under warranty. Submit warranty service through the Warranty Center (supporttickets.intel.com).
Support and services for the Intel® Partner Alliance partners through the Intel® Partner Alliance support site (https://www.intel.com/content/www/us/en/secure/partner-alliance/overview.html)
Help from other users in the Intel Support Community (https://community.intel.com/)
We no longer respond to telephone, chat, community support forum, or email inquiries for self-service products.
Thank you & Best Regards
Devi_Intel
Hi Devi_Intel,
thank you for clarifying and yes, I was hoping for help from other users. Is this still the right forum for help from the community?
Thank you & best wishes,
Klaus
