Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4482 Discussions
Getting "Flash downloaded image corrupt" trying to upgrade a RS2BL040 RAID controller.
DHugh3
Getting "Flash downloaded image corrupt" trying to upgrade a RS2BL040 RAID controller with current firmware 2.003-0673 from packet 12.0.1-057 July 25 2009. I have downloaded versions 12.14.0-0185,12.14.0-0167,12.13.0-015 several times each and tried doing the flash with the packaged command line tool, and the GUI interface; and got the same error every time. Running the flash from a SUSE Linux 13.2 box.
Please proceed to download and run the following firmware update before going to the latest one and let us know the results:
https://downloadcenter.intel.com/download/19696/6GB-SAS-Hardware-RAID-Firmware-Flash-Update-for-DOS-... Intel® Download Center
DHugh3
The earlier version worked, and then I could do the latest. Thanks.
