Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Good day, Are these RAMs compatible with the CT32G4RFD4266 Crucial DRAM 32GB DDR4 2666 MT / s (PC4-21300) CL19 DR x4 ECC Registered DIMM 288pin? We know that these RAMs are suitable for the motherboard, but are they suitable for existing RAMs?
We have a server: Intel® R2312GZ4GS9
plateau mat on it: Intel® Server Board S2600WT2R
RAM requirements for it: DDR4 ECC RDIMM / LRDIMM 1600/1866/2133/2400
There are already 2 RAM slots of the following model, 32 GB each:
Kingstone 9932090-001.B00G
data from CPU-Z to RAM:
Part Number: KSM24LD4 / 32HMI
BOM Number: 9932090-001.B00G
Product Description: 32GB DDR4-2400 Load Reduced DIMM CL17 2Rx4 1.2V Hynix M Die with IDT (Server Premier)
We need to buy RAM in addition to these two so that the total memory is 128 GB.
Highlighted
Re: Good day, Are these RAMs compatible with the CT32G4RFD4266 Crucial DRAM 32GB DDR4 2666 MT / s (PC4-21300) CL19 DR x4 ECC Registered DIMM 288pin? We know that these RAMs are suitable for the motherboard, but are they suitable for existing RAMs?
Would it be possible for you to provide the PBA or the serial number of your motherboard?
Franklin S.
Highlighted
In order to better assist you, and if you still need our help, we will need you to please provide the PBA or the serial number of your motherboard.
Franklin S.
If you have any other questions or concerns please let us know and we will be happy to assist you.
Franklin S.
