Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4776 Discussions
Good day, Are these RAMs compatible with the CT32G4RFD4266 Crucial DRAM 32GB DDR4 2666 MT / s (PC4-21300) CL19 DR x4 ECC Registered DIMM 288pin? We know that these RAMs are suitable for the motherboard, but are they suitable for existing RAMs?
ЕАман
We have a server: Intel® R2312GZ4GS9
plateau mat on it: Intel® Server Board S2600WT2R
RAM requirements for it: DDR4 ECC RDIMM / LRDIMM 1600/1866/2133/2400
There are already 2 RAM slots of the following model, 32 GB each:
Kingstone 9932090-001.B00G
data from CPU-Z to RAM:
Part Number: KSM24LD4 / 32HMI
BOM Number: 9932090-001.B00G
Product Description: 32GB DDR4-2400 Load Reduced DIMM CL17 2Rx4 1.2V Hynix M Die with IDT (Server Premier)
We need to buy RAM in addition to these two so that the total memory is 128 GB.
Franklin_S_Intel
Would it be possible for you to provide the PBA or the serial number of your motherboard?
Franklin S.
Under Contract to Intel Corporation
Franklin_S_Intel
In order to better assist you, and if you still need our help, we will need you to please provide the PBA or the serial number of your motherboard.
Franklin S.
Franklin_S_Intel
If you have any other questions or concerns please let us know and we will be happy to assist you.
Franklin S.
