Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4852 Discussions
Graphics card NrVidia Grid Certified
ThomasATM
We have a M50CYP2SB1U intel server. We cannot find sort of documentation that states whether the server is NVidia Grid certified or not.
We need to be able to share the GPU up to the VMs that are located on the host through Hyper-V.
We see other server models with the Intel® C621A Chipset that are Grid certified but nothing on this particular server that states whether it is or not.
Can anyone confirm?
BrusC_Intel
Hello, ThomasATM.
This post is to inform you about the closure of this thread regarding the validated components for this server platform.
I previously shared that the card you mentioned is not listed, which does not mean it will not work, but any type of testing, validation and implementation will have to be performed personally by the interested users under their own risk/expense, and there was no response from your part after I tried to follow up
Additionally, the validated/tested hardware for the CYP and other platforms can be found here:
- https://servertools.intel.com/sct/compatibility-tool/M50CYP
The thread will be closed right now, and it will no longer be monitored by Intel support, but if you require any type of assistance from Intel in the future, just open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
BrusC_Intel
Hello, ThomasATM.
Thank you for posting on the Intel Community Support forums.
I received your thread regarding the validation of NVIDIA hardware, and I will be reviewing this with you.
The validated/tested hardware for the CYP and other platforms can be found here:
The card you mentioned is not listed, which does not mean it will not work, but any type of testing, validation and implementation will have to be performed personally by the interested users under their own risk/expense.
If you have other questions, please let me know, and I will follow up on March 24th just in case.
Bruce C.
BrusC_Intel
Hello, ThomasATM.
I wanted to follow up on this support thread to check if we can help you with anything else.
The thread will be closed on August 29th if there is no confirmation, but we can move this to a later date if needed.
Bruce C.
BrusC_Intel
Hello, ThomasATM.
Bruce C.
