Server Products
4784 Discussions
Grub and S5000PSL
I have just gotten this motherboard and have 8gb of 1x8 fb-dimms ddr2 and dual quad xeon e5345 chips, I can't seem to get grub to work on this system while lilo and freebsd's boot loaders work, does any one else have this problem. Also has any one managed to get Solaris 11 working on this motherboard s/and/or processor combo. I'm kinda puzzeled to why it wont start, as it gives me no error codes or output to work with it simply sits at 'GRUB'
Any information pertaining to this would be helpfull, will update this thred with board model # and stuff when I get home .
As I said prior I would get the boards details.
System Bios: V S5000.86B.10.00.0081
Build Date: 08/17/2007
Board Part Number: D44771-805
Board Serial Number: QSSL73201090
System Part Number: C2001
System Serial Number:A0047780
Chassis Part Number:C2001
Chassis Serial Number:C2001
BMC Firmware Revision: 0.59
HSC Firmware Revision: 0.00
SDR Revision: SDR Package 42
UUID: D3E6ED81479811DCAF6A00151730A1D4
-----------------------cut
dmidecode -q output
BIOS Information
Vendor: Intel Corporation
Version: S5000.86B.10.00.0081.081720071348
Release Date: 08/17/2007
Address: 0xE8000
Runtime Size: 96 kB
ROM Size: 4096 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
BIOS Revision: 10.0
I don't know if this will help with the diagnosis of my situation
I also wanted to know if it would be safe to upgrade the bios, on boot it says the Bios is a American Megatrends Bios branded Rackable Systems and the board is intel, would the intel firmware on the intel site be safe to use? I don't want to brick this system as I just got it lol
As per this link
http://www.brianstempin.com/2011/11/11/grub2-do-not-want/ http://www.brianstempin.com/2011/11/11/grub2-do-not-want/
The issue is that the grub2 don't play well with this board. So as in the link the fix is to use a older version of grub . I did this and all works well with Solaris 11 on this system =D
