Community
cancel
Showing results for
Search instead for
Did you mean:
HTTPS is enabled and configured for port 443, but port 443 remains closed.
Jump to solution
I stumbled upon this thread because I currently have the same problem. HTTPS is enabled in Configuration > Security Settings and configured for port 443, but port 443 remains closed. I know, this did work some time ago, but I can't remember when I last used it. I also tried
sudo ipmitool mc reset cold
but to no avail.
Any tips for further debugging?
Best,
Hauke
Accepted Solutions
Community Manager
Hello HaukeM,
You may need to first upload a SSL certificate to BMC. The steps to do that can be found at http://download.intel.com/support/motherboards/server/sb/intel_rmm4_ibwc_userguide_r2_72.pdf page 90 section 7.3.7
Sergio S.
Community Manager
Hello HaukeM,
Sergio S.
Thanks, Sergio, that did it.
Community Manager
Hello Hauke,
I am glad to hear that I was able to assist you.
Best Regards.
