Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Has anyone successfully used 32GB DIMMs in the S5520HCT?
Jump to solution
I have the opportunity to upgrade my S5520HCT based server with cheap Micron 32GB PC3-10600 DDR3-1333MHz ECC however I am not sure if it is possible to use 32GB DIMMs on this server board?
Norm
Accepted Solutions
Highlighted
Re: Has anyone successfully used 32GB DIMMs in the S5520HCT?
Jump to solution
The largest memory module that Intel has validated for this board is a 16GB module. Intel always encourages our customers to use validated configuration to avoid unforeseen issues.
Intel offers a validation list as a reference of possible part numbers to use for your system.
http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030220.htm Tested Memory and Hardware List
Additionally, Intel has the http://imct.intel.com/ Memory Configuration Tool to assist you on the proper population based upon the board, and processor you have.
Highlighted
Jump to solution
