Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
Health Sensor Problem with S2600WTTR/S2224WTTYSR/LSI 9266-8i
SDiem
Hi
We have three identical servers:
-Mainboard S2600WTTR / Bios SE5C610.86B.01.01.0019.101220160604 / BMC 1.47.10181
-Chassis R2224WTTYSR
-Controller LSI Megaraid 9266-8i / 23.34.0-0019
-Samsung Pro 2 TB SSD Drives
Problem:
On two Servers with ESXi 6.5 after a few hours of operation, single or multiple drives (even non-populated slots) will flash orange.
In the integratet BMC, warnings are logged.
But the LSI/AVAGO Megaraid Storage Manager does not display a problem.
After a restart (power-off/on !-not just restart) all Warnings lights are gone. But after a few hours they will be displayed. (not always the same drives - its random)
On the one with Windows 2016 Server - No Issues !
Any ideas ? any help is appreciated! Thanks in advance!
Hello Siliconbrain,
The only missing piece of information here is the current driver LSI driver version running on ESXi.
Checking at the LSI website the latest driver available is:
Which redirect you to the following VMware download locations:
6.913.05.00
ESXi 6.5 Native driver
https://my.vmware.com/web/vmware/details?downloadGroup=DT-ESXI65-AVAGO-LSI-MR3-69130500-1OEM&productId=614 https://my.vmware.com/web/vmware/details?downloadGroup=DT-ESXI65-AVAGO-LSI-MR3-69130500-1OEM&productId=614Try to update this driver if not already.
After that we will need to start troubleshooting the HDD backplane, cables and hardware in general.
Let us know.
Jose H.
SDiem
Hi Jose
Thanks for your quick reply.
Such a shame, the original driver from the intitial esxi-setup was activ.
I have installed the driver you suggested.
VIBs Installed: Avago_bootbank_lsi-mr3_6.913.05.00-1OEM.650.0.0.4598673
VIBs Removed: VMW_bootbank_lsi-mr3_6.910.18.00-1vmw.650.0.0.4564106
I will now monitor the Server for a while (2-3 days) and report the result here.
Greetings Silvan
Great,
Just let us know when you have the update
Jose H.
SDiem
Hi Jose
Sorry for the delay. Unfortunately the problem still occurs.
HDD3 permanent red, HDD7 blinking
In the RMM Log:
MSM looks still ok:
What steps would you do now?
Thanks in advance.
Hello Siliconbrain,
I'm sorry to hear about the issue persist.
In this case, due to the complexity of the issue, it would be recommended for you to contact us over the phone support line. You can get the number from the following URL: http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
In order to have all the info available handy you could get the system logs using the sysinfo tool (https://downloadcenter.intel.com/download/25437/Intel-System-Information-Retrieval-Utility-SysInfo-?product=88281 https://downloadcenter.intel.com/download/25437/Intel-System-Information-Retrieval-Utility-SysInfo-?product=88281) before calling.
Hope this helps.
Jose H.
SDiem
Hi Jose
Thank you for the reply. I will update the Server Board to the newest Firmware (https://downloadcenter.intel.com/download/26716/Intel-Server-Board-S2600WT-BIOS-and-Firmware-Update-for-EFI?product=88281 Download Intel® Server Board S2600WT BIOS and Firmware Update for EFI ) first and if the problem still persist i contact intel support as you recommend.
best regards.
Hi Siliconbrain,
Sounds like a plan. Thanks for the update.
If you need something else just let us know contacting us using any of the means available.
Jose H.
SDiem
