Two nodes are loaded into the chassis H2224XXLR3,the node Module is iPC – HNS2600BPB24R.
In BIOS advance , system acoustic and performance configuration, default value is acoustic, in this case, the system fans always maintains 6K speed, the rear side of the chassis accumulates heat, the CPU1 temperature is very high, the temperature of the optical SFP module reaches above 60 degrees, and can not work properly. But BMC has no alarm prompt.
Modified to performance value, the system fan runs at full speed, more than 13000 revolutions. The voice is very noisy.
Two Xeon silver 4214 processors are configured in the system,firmware version: S2600BP_EFI_BIOSR02010008_ME04.01.04.251_BMC1.93.870CF4F0_FRUSDR_1.39_DCPMM01.02.00.5346
Dear all: please dont close. We found another strange problem. After updating the whole firmware completely,from the BMC Web we can check that the "exit air sersor" sensor had output data, but when the server lost power supply and restarted power again, the "exit air sersor" sensor status showed Unknown, and the fan speed was not normal.
sorry , node Module is HNS2600BPS24R.
Hello DYu001,
Can you please let us know if this problem started after you perform the firmware update?
Please install and run the System Information Retrieval Utility (SysInfo) and attach the information.
https://downloadcenter.intel.com/download/28712/System-Information-Retrieval-Utility-SysInfo-
Also, please let us know if after modifying the values the system temperature decreased.
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Hello DYu001,
We are going to check the log files and will get back to you.
Sergio S.
Intel China engineer jeason.tian help me to find out the error that I modified fru information, resulting in SDR update failure.
we can closed the issue.
Hello du Yu,
We are going to proceed a close this thread as per your request.
Sergio S.
