What heatsink/cooler would you recommend for an Xeon 3450 or 3460 processor? These use the LGA1156 socket and output 95W of heat.
If you got the boxed processor, use the fan and heatsink that came in the box. If you're using tray processors, there is a list of heatsink vendors in Appendix A of the Thermal Mechanical Specifications and Design Guidelines at http://www.intel.com/Assets/PDF/designguide/322171.pdf http://www.intel.com/Assets/PDF/designguide/322171.pdf
