Server Products
4778 Discussions
Help me choose memory modules
MK19
I have a motherboard S3420GPLX and processor Xeon X3450.
http://ark.intel.com/ru/products/46545/Intel-Server-Board-S3420GPLX http://ark.intel.com/ru/products/46545/Intel-Server-Board-S3420GPLX
http://ark.intel.com/ru/products/42929/Intel-Xeon-Processor-X3450-8M-Cache-2_66-GHz http://ark.intel.com/ru/products/42929/Intel-Xeon-Processor-X3450-8M-Cache-2_66-GHz
I want to install 32 GB of memory.
Now we can buy such modules:
Kingston ValueRAM KVR13R9S4L/8 DDR-III DIMM 8Gb PC3-10600 ECC Registered with Parity CL9
Kingston ValueRAM KVR16LR11S4/8 DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity CL11
Kingston ValueRAM KVR16LR11S4L/8 DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity, Low Profile CL11
Kingston ValueRAM KVR16R11S4/8 DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity CL11
Kingston ValueRAM KVR16R11S4/8I DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity CL11
Kingston ValueRAM KVR18R13S4/8 DDR-III DIMM 8Gb PC3-15000 ECC Registered with Parity CL13
Kingston ValueRAM KVR16E11/8 DDR-III DIMM 8Gb PC3-12800 CL11 ECC
Kingston ValueRAM KVR16LR11D8/8 DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity, Low Voltage CL11
Kingston ValueRAM KVR1333D3E9S/8G DDR-III DIMM 8Gb PC3-10600 ECC CL9
Kingston ValueRAM KVR13LE9/8 DDR-III DIMM 8Gb PC3-10600 CL9 ECC
Kingston ValueRAM KVR13LR9D8/8 DDR-III DIMM 8Gb PC3-10600 ECC Registered with Parity, Low Voltage CL9
Kingston ValueRAM KVR13R9D8/8 DDR-III DIMM 8Gb PC3-10600 ECC Registered with Parity CL9
Kingston ValueRAM KVR16E11/8I DDR-III DIMM 8Gb PC3-12800 ECC CL11
Kingston ValueRAM KVR16LE11/8 DDR-III DIMM 8Gb PC3-12800 CL11 ECC, Low Voltage
Kingston ValueRAM KVR16R11D8/8 DDR-III DIMM 8Gb PC3-12800 ECC Registered with Parity CL11
Kingston ValueRAM KVR18E13/8 DDR-III DIMM 8Gb PC3-15000 ECC CL13
Kingston ValueRAM KVR18R13D8/8 DDR-III DIMM 8Gb PC3-15000 ECC Registered with Parity CL13
Which memory modules are compatible with this motherboard?
We recommend checking the list of validated&tested memory at the following website:
http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030738.htm Intel® Server Board S3420GP Family — Memory and Hardware Compatibility
We also recommend checking the memory specifications from the Technical Product Specification page# 2:
http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030742.htm Intel® Server Board S3420GP Family — Technical Product Specification
AP16
Valued Contributor III
