Hi The Server Room :: I want to build a web server, but I do not know what is the correct power supply (wattage) for this server motherboard, Intel S5520HC Server Motherboard - Intel Chipset SSI EEB - Socket B LGA-1366 - 96 GB DDR3 SDRAM - Serial ATA/300.
And what is the correct heatsink&fan for this microprocessor Intel Xeon DP Quad-core E5520 2.26GHz Processor - 2.26GHz - 5.86GT/s QPI - 8MB L3 - Socket B LGA-1366
Hope someone can help me to obtain the information. Any kind of observation is good.
Thanks and Best Regards !!!!
Check http://www.intel.com/support/motherboards/server/sb/CS-030487.htm - minimum wattage looks like 600.
For the heatsink, depends on which processor you choose. Fortunately, the list at http://www.intel.com/support/motherboards/server/sb/CS-030213.htm tells you the correct order code down at the bottom
