Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4761 Discussions
Help to decode diagnostics LED fault - Intel Server Board S5000PSL
JPete15
Hello folks,
One of my servers are having a problem booting and hangs before anything is displayed on the monitor.
The server has been running fine until it was shutdown. When I needed to start it again, this problem occured.
It shows the following on the four diagnostic LEDs:
MSB = Green
Bit 2 = Off
Bit 3 = Off
LSB = Red
Status LED = Blinking (some times solid greed)
I haven't been able to find this combination in the product specification pdf. Thanks for your help.
Best regards
Jesper
Daniel_O_Intel
I checked around in five or six different TPSes, and didn't see "green off off red" or "g off off r" in any of them.
Specifically, the S5000PSL TPS (which applies to any of the S5000 server boards) jumps from 'g off r off' (0x28h) to 'off r off r' (0x50h), entirely skipping 'g off off r' (0x42h, if I am reading the decoder correctly).
For general memory/pci bus troubleshooting, I might try only one DIMM, and remove all possible PCI devices, and see if you can either get a beep code or display that way.
JPete15
Hi Dan_O
It appears that the motherboard was defective. I've gotten it RMA'ed now.
Funny how no information on that specific error code exists.
-- Dfir.
