Server Products
4778 Discussions
Help with setting up SAS/SATA in SR1550ALSASR
BSeyi
I bought Intel server SR1550ALSASR and I have been struggling to set it up for three weeks.
The seller told me that the server takes either 2.5" SAS or SATA, so I first bought 2TB of SATA but only to realise that whereas the embedded RAID sees the disks, the BIOS doesn't. The server has 'Active SAS/SATA Mid-Plane'. I also bought SAS disks and tried that too but again, the embedded RAID can find the disks but the AMI BIOS F2 Setup doesn't show any disk.
I have many years experience of setting up and using servers, and they usually take me a few hours, but this Intel server has been a nightmare to set-up.
What could I be doing wrong:
1. I have updated the BIOS and firmwares.
2. The SAS are made by HP; and SATA are by Seagate, but none is seen in the BIOS Setup screen.
3. On POST, I can see the disks light on briefly.
4. I can configure both the SAS and SATA disks in the embedded RAID (using RAID 0).
5. I try to set up Linux using LVM (instead) but this failed too due to the disk detection.
I wonder what is different about this Intel SR1550ALSASR server from other servers that I have used and still use.
Thanks (and excuse my tone).
Daniel_O_Intel
http://www.intel.com/support/motherboards/server/sb/CS-022920.htm Server Products — Hardware, Memory, and Operating System Compatibility only shows 3.5" sas, and all pretty old models. Do you have anything 600GB or smaller, 15k RPM, 16MB cache?
BSeyi
Thanks for your respond. What I have actually tried are:
(10 4 x 500GB 2.5" Seagate Momentus 7200.4.
(2) 3 x 146 2.5" Seagate Savio 10K.3.
I found this link:
http://download.intel.com/support/motherboards/server/sb/hdd_test_report_rev_23_0.pdf http://download.intel.com/support/motherboards/server/sb/hdd_test_report_rev_23_0.pdf
[Revision – 1.3 October 2007]
And saw the following compatible disks:
Seagate* Momentus 7200.1 and 7200.1 2.5"
Seagate Savio 10K.2, 147GB 2.5"
These are the closest to my Seagate Momentus 7200.4. and the Seagate Savio 10K.3 respectively.
Additional question:
Does the SR1550AL support JBOD or all disk must be install via RAID?
SWood11
ok so sounds like you have the active midplane that supports both SATA/SAS. this midplane is its own 8 port sata/sas controller and offers no jbod mode to release single drives to BIOS. try configuring a single drive as its own raid 0 to release to the BIOS (F2) and OS level.
see page 13 of pdf
http://download.intel.com/support/motherboards/server/sb/d31972002_sr1550_user_guide_092506.pdf http://download.intel.com/support/motherboards/server/sb/d31972002_sr1550_user_guide_092506.pdf
BSeyi
Thanks but I am still having problem installing OS in the server.
1. After configuring the disk in RAID 0, I still don't see the disks in BIOS F2 display. Or is this normal?
2. I then try to install Linux on the server but it aborts every time -- due to (disk) formatting error.
Is there something I am missing between step # 1 and step # 2 above?
