Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4801 Discussions
Hoe to activate a pci graphic card on M10JNP2SB with xeon 2224 without GPU function?
AKD
Hi there, i have a M10JNP2SB mainboard and added a xeon e2224 which has no graphic support. Hence I cannot use the onboard VGA. So I added a graphic card i to a PCI-e slot. But that graphic card doesn‘t give me any output. It looks like the BiOS setting is set to use the onboard graphic card, which cannot be used as the CPU doesn‘t support it. How can I do changes in the BIOS to activate the added Graphic card in the slot? Any possibility to access tje Web-BIOS when using A DHCP server? Thanks for any hints
JoseH_Intel
Hello AKD,
Thank you for joining the community
The Baseboard Management Controller (BMC) is the one who provides the video and the output is via VGA port (D-Sub connector)
This information can be confirmed at the section named Product Architecture Overview (Figure board block diagram) of the document shown below:
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/m10jnp2sb-user-guide.pdf#page=18
Hope it helps:
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
JoseH_Intel
Hello AKD,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this ticket as closed. I will try to reach you as a very last time on next Monday 18th. After that we will mark the thread as archived.
Jose A.
AKD
Thanks Jose. So I‘m in a trap as the CPU has no graphic support to enter BIOS to setup a user and password for the BMC. Thx
JoseH_Intel
Hello AKD,
By any chance do you have another graphics capable processor that you can use just to access BIOS and setup the BMC? The VGA port is supposed to have a video signal even if you are using a non-graphics processor. When using a graphics capable CPU, the video signal goes through the Display ports.
Jose A.
AKD
I‘m waiting one an extra CPU to try. However, are you sure that the PCIe Graficcard is activated in the BIOS by default? Thx
JoseH_Intel
Hello AKD,
I just confirmed the VGA port is for the BMC graphics and is independent from the CPU graphics. That doesn't mean that a PCI graphics will be enabled from BIOS by default, but you should be able to get a video signal.
Jose A.
AKD
right, that is my understanding too. But since this is a new Mainboard no user and password for BMC was defined yet. Therefore I cannot log in. So I have no way to activate the PCIe Graphic card unless I have aCPU to support the online grapic card to enter the BIOS.
JoseH_Intel
Hello AKD,
Well yes, you are correct. In such case just let us know when the new CPU arrives.
Jose A.
JoseH_Intel
Hello AKD,
Just following up to ask about the new CPU ordered. I will try to reach you back on next Monday 25th.
Jose A.
JoseH_Intel
Hello AKD,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
