Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4803 Discussions
How much maximum hard drive capacity and ECC or non-ECC memory on Intel S3420GPV?
Hi...
I'm plan to build a SOHO server. And i'm curious about maximum hard drive capacity on Intel S3420GPV. I'm planning to use the server as a small database server, data storage. And also what kind of memory that i have to use it, is it the DDR3 ECC or DDR3 non-ECC vesion?
Thank you.
Edward_Z_Intel
I'd always suggest you stick with the http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030737.htm Tested hardware list. Currently the lagest test HDD is 2TB. Non-ECC memory is not supported. Again check the http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030738.htm Tested memory list
