Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4832 Discussions
How to add single harddrive
Hi everyone,
This is a stupid question but I have been trying and looking everywhere without success.
I have a S5000 board, with Intel Raid Technology II. Two raid1 1TB drives are configured...and I want to add one simple 2TB drive. Now I saw in the manual the I should create a new mirror array, with this only drive in it. I have tried everything but I just don't see how.
Please help me .
Kind regards,
Stephane
Edward_Z_Intel
You can create a RAID 0 VD with that single hard drive. RAID 1 (Mirror) requires at least two drives.
My mistake, I meant Raid 0.
That was not the main issue... the issue was that I just couldn't find where to do this! Finally I did, there is an extra step one has to do ... now I don't remember exactly the right terms, but once you have selected your second array, press "enter" or F10, you will have a little windows opening and there you have to type on the space bar to have "span" filled in that window. And then finally you can create the raid.
I have never seen such a poor interface... but it works now .
Thank you for your response.
