Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4482 Discussions
How to check error statistics in Intel C627 QAT?
Alfago12
Hi Team,
How to check error statistics in Intel C627 QAT? I searched the related documents but failed to find the answer myself. I've attached a file named "Intel_C627_QAT_statistics.txt" acquired from my device. What's the possible configure should I use? And in which directory should I search because the files in "Intel_C627_QAT_statistics.txt" seems unrelated with what I want?
I'm using Intel C627 QAT in my server. When use Sprient tester and simulate many concurrent users, the application has a OpenSSL 281 error which means "decryption failed or bad record mac".
The OpenSSL 281 error may be caused by the following reason.
The bad MAC (message authentication context) error is OpenSSL detecting a problem with the integrity of your communication layer. Normally this means that your packets are out of order or that you have lost some bytes.
Try doing a simple checksum of your encrypted data client and server side. You'll probably find that you've miscalculated a buffer size or something. Maybe you've got some packet fragmentation...
https://openssl-dev.openssl.narkive.com/z3GvY5Q4/decryption-failed-or-bad-record-mac-error-on-ssl-co...
The related QAT software version is as follows.
Driver: QAT1.7.L.4.18.1-00001
engine: QAT_Engine-0.5.46
Victor_G_Intel
Hello Alfago12,
Thank you so much for waiting.
The QAT related debug information is available at /sys/kernel/debug/qat_*, which is the content shown in the text file you provided. So from a QAT standpoint, you are looking at the right place. However, all fw_counters are at 0 which means the QAT endpoints have not been used. That means the application errors seem to be not QAT related because QAT was not even used to process any requests. Therefore, our best recommendation is for you to check your setup piece by piece. The first step is to make sure QAT is working as expected by running the sample application code. If it runs, then it means QAT works fine, then you can go to the next step and test the application you are using along with QAT to isolate where the root cause could be.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Alfago12,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Victor_G_Intel
Hello Alfago12,
Victor G.
Alfago12
Thanks Victor,
Let me check on my side.
Alfago12
Hi Victor,
To transmit data over TLS, firstly TLS handshake should be finished and then the application data will transferred over TLS.
Which phrase does QAT engage in: only TLS handshake, or both TLS handshake and application data transferring over TLS? Thanks.
Victor_G_Intel
Hello Alfago12,
Thank you for your response.
Take as much time as you need and let us know if you will be needing anything else afterward.
Victor G.
Victor_G_Intel
Hello Alfago12,
Please allow me to investigate this further. Once I have more information to share, I will post it on this thread.
Victor G.
Victor_G_Intel
Hello Alfago12,
Thank you for your patience.
In regard to your question, QAT engages in both phases of TLS handshake and data transferring over TLS. Basically, what QAT does is offload the computation of cryptographic-related operations that may happen during the TLS handshake or during data transferring over TLS.
Victor G.
Alfago12
Thanks Victor for your detailed explanation.
Victor_G_Intel
Hello Alfago12,
I’m glad that you found the information provided helpful. Since the thread is now solved, we will proceed to close it.
Victor G.
Alfago12
Thanks Victor, will do as instructed.
