Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
How to (re) enable http/https service for BMC web console (RMM4)
How can I enable http/https service on the RMM4 when it has been disbaled and the web console is not available anymore?
Our best recommendation is checking the :
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006023.html User Guide for Intel® Remote Management Module 4 (Intel® RMM4) and Integrated BMC
Basically we recommend checking that the configuration you have is correct. If so, there is a chance the module is defective and you will need to contact our support group to replace it under warranty:
http://http//www.intel.com/content/www/us/en/support/contact-support.html Contact Support
thank you for your quick response.
Sorry for the misunderstanding, but the http/https service was disabled by myself using the web console.
I initially thought I could just re-enable it using SMASH console or IPMI, but I just couldn't find a way to access the http/ web service settings. The RMM4 User guide does not consider this case. I guess the only option is a factory reset using SYSCFG. Or what method do you recommend resetting RMM4 to default settings?
Your affirmation is correct, the way to reset it is using the SYSCFG. Here are the commands:
- Reset System Configurations: /RestoreFirmwareSettings or /rf
- Reset the BMC: /ResetBMC or /rbmc
