Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4615 Discussions
How to rre- enable onboard video on S2600IP4, after disabling it in bios?
whilst trying to figure out how to passthrough GPU cards in esxi, one of ways suggested was to disable onboard video.
It did not make any difference and now I cannot get onboard video back.
can anyone point to me how to do so?
much thanks!
Thank you for contacting Intel Customer Support.
My recommendation for this case is to set BIOS to default. Here I will share the Technical Product Specification for your http://download.intel.com/support/motherboards/server/sb/g34153004_s2600ip_w2600cr_tps_rev14.pdf Intel® Server Board S2600IP4, in page 104 you will find all the instruction for this proceedure.
faugub_intel # iwork4intel
Thank you for your reply.
I have tried as per procedure stated on the manual, but there is still no video output. So I cannot even get into the bios.
Must I remove all the cards from the PCI slots?
thanks
EDIt: I removed all the cards and I can finnaly reset bios to default. Thank you
