Server Products
4778 Discussions
I am searching for a GbE NIC with scatter gather capabilities
I need 8194 Bytes of data per packet but this can be changed to gain advantage.
I also need its driver, library and header file so that I can include this into a National Instruments Labwindows CVI program.
What do you recommend?
archieb
Daniel_O_Intel
Intel® Ethernet Server Adapter I340 (http://www.intel.com/Products/Server/Adapters/esa-i340/esa-i340-overview.htm http://www.intel.com/Products/Server/Adapters/esa-i340/esa-i340-overview.htm) is based on the Intel® 82580 Gigabit Ethernet Controller
The 82580 supports scatter/gather - see download.intel.com/design/network/specupdt/322444.pdf
