In this case slot 0. I have replaced the drive and it goes through the rebuild then shows failed again. To continue to troubleshooting I replaced the mother board and rebuild the array. When I left the server the array was rebuilding. I came back and the array is showing the drive in slot 0 failed again. I am seeing the following message in the logs in the Intel RAID Web Consile 2. " ID 113, Error Level [Information, 0] Description Controller ID:0 Unexpected sense: PD = 0-No additional sense information, CDB = 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00, Sense 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x80 0x00 0x02. Any idea what is wrong. Like I said I replaced the drive and then the motherboard. I am not sure what is going on. Note that the first drive I pulled passed a disk diagnostic with flying colors. Thank in advanced for any insight to this issue. I also set up email reporting and got this message from the server.
Controller ID: 0 VD is now DEGRADED VD
0
Event ID:251
Generated On: Fri Mar 13 19:33:39 MDT 2015
System Details---
Server IP:169.254.180.143
OS name:Windows
OS Version:unknown
Driver Name:LSI MegaSR RAID5
Driver Version:16.01.2014.0318
Image Details---
BIOS Version : A.11.02151531I
TSC
Additional information on this. I replaced all the SATA cables on this computer and rebuilt the array. I got the following log entries during the rebuild:
ID = 102
SEQUENCE NUMBER = 129
TIME = 14-03-2015 13:05:10
LOCALIZED MESSAGE = Controller ID: 0 Rebuild failed due to target drive error: PD 0
ID = 113
SEQUENCE NUMBER = 128
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = 0No addtional sense information, CDB = 0x2a 0x00 0xd5 0x65 0x52 0x00 0x00 0x00 0x80 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x80 0x00 0x02
ID = 113
SEQUENCE NUMBER = 127
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = 0No addtional sense information, CDB = 0x2a 0x00 0x03 0x89 0xc8 0x78 0x00 0x00 0x08 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x80 0x00 0x02
Does this help anyone define the cause of the problem?
Thomnas
