Server Products
4957 Discussions
I have an server with S2600CP mother borad. Now windows 2008 R2 installed in it with 8x4TB HDD. Please let me know the maximum capacity of Hard Drive for this Mother Boards. If I upgrade the OS to 2012 will this mother board support 64 TB disk.
AJose3
Hello All,
I have an server with S2600CP mother borad. Now windows 2008 R2 installed in it with 8x4TB HDD. Please let me know the maximum capacity of Hard Drive for this Mother Boards. If I upgrade the OS to 2012 will this mother board support 64 TB disk. 8x8 TB HDD.
Many Thanks,
Austin Jose
KL2
Valued Contributor I
It should work, but there are limitations, and even taking all of those into account, you're kind of on your own.
512e HDD's only if you're using the onboard controller, BIOS R02.03.0004 or higher required, UEFI mode required:
http://download.intel.com/support/motherboards/server/sb/ta10852.pdf http://download.intel.com/support/motherboards/server/sb/ta10852.pdf
If you're planning on a single 8 x 8TB RSTe RAID volume (64TB), it looks like RAID 0 is your only option -- and, honestly, it's not a great idea, since the chance of failure on RAID 0 goes up exponentially with every drive added. http://www.intel.com/content/www/us/en/support/boards-and-kits/000006143.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000006143.html
You also require the appropriate C600 RAID Upgrade Key to unlock the SATA/SAS ports:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006327.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000006327.html
If it were me, I'd buy a hardware HBA / RAID controller, since they generally have better support for large disks / arrays. Or, I'd use Windows Server Storage Spaces with a seperate boot drive...
Cesar_B_Intel
Hello Austin_RM ,
As Gize2 mentioned, the configuration you are planning should work, however, please takeGize2's recommendations into consideration.
Caesar B.
Please let us know if you have any more questions,
Caesar B
Hello Austin_RM ,
We want to confirm if further assistance is required.
Caesar B.
