Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4482 Discussions
I have motherboard S5500BC and 1 installed processor Xeon E5520. I want to replace all the memory. I bought 2 of the Kingston (Hyperx Furry HX318C10F/8). Each module is 8 GB. After you install the new memory - server starts but complains about the followi
ФСтец
I have motherboard S5500BC and 1 installed processor Xeon E5520. I want to replace all the memory. I bought 2 of the Kingston (Hyperx Furry HX318C10F/8). Each module is 8 GB. After you install the new memory - server starts but complains about the following errors: 8542, 8522, 85E0. What am I doing wrong? Or this memory will not work on the motherboard S5500BC processor-Xeon E5520?
AKroe
Hi Philip,
check this site http://www.kingston.com/en/memory/search?DeviceType=8&Mfr=INT&Line=S5500BC&Model=54353 Memory Search for Info on the memory, Other Manufactures have similar sites.
This may also help.
Kind regards
Andreas
ФСтец
Did I understand you correctly that I can't put the memory module 8 GB?
But nowhere is written, not that this motherboard does not support memory module 8 GB.
Why, then, the motherboard starts up and gives log, in the BIOS? (Installed memory is 2 modules of 8 GB. Only 16 GB.)
