We Need IBIS models for the List below for Running Our Signal Integrity Analysis using Hyperlynx.
1. Skylake Processor
2. Lewisberg (C620 Series ) Chipset
3. X550-AT2 [ PHY]
In addition , is There any Document or guidelines For Signal Integrity for Purley platform?
Hello Syed,
Thank you for contacting Intel® Technical Support.
I understand that you are looking for I/O, Buffer, Information, Specification (IBIS) models for specific Intel® Products.
For this type of request I recommend you contacting our Intel® Contact Support. We can be reach at the following option:Phone North America Customer Support Center Phone Number: (916) 377-7000Business Hours: Monday - Friday 7:00 AM to 5:00 PM (Pacific Time)
Please let me know if there is anything else I can help you with.
Jeremiah A.
Hello Syed,
I hope you are doing well today,
I'm following up with you to see if there is something else I can help you with or if we can proceed in closing this case?
Jeremiah A.
Intel(R) Technical Support
Jeremiah,
We Still have No access To the IBIS models , to Proceed with our analysis.
Our Calls Were Left unanswered.
Request you to kindly help Us with Our Analysis for Purley platform Design.
Hi Syed,
Let me investigate about this request and get back to you as soon as possible with information.
regards,
Jeremiah A.
Hi Syed,
I hope you are doing well today.
We will contact you directly to assist you with this request.
regards,
Jeremiah A.
Jeremiah,
We Still havent Received Any Responses.
I will be Reachable on - mailto:zaid@velankanigroup.com zaid@velankanigroup.com or on skype - s_zaid_a.
Request you to kindly get in touch with us.
Hello Syed,
Thank you for the information. We will contact you as soon as possible.
regards
Jeremiah A.
Hello Syed,
Can you please confirm the Intel(R) department you tried to contact in order to obtain the information? Did you use the contact information I provided you in my first response?
regards,
Jeremiah A.
Jeremiah,
Our calls Were Left unanswered.
Monday - Friday
How Ever We have Contacted Out Local Indian representative ( Mr. GOvind ) and the responses were Not as Desired.
We have Not received any IBIS models or Links.
Kindly request you to Help Us With this Issue.? Our Target Is to run Signal Integrity analysis.
Jeremiah,
Any update on the IBIS models.
As an initial Step , We Would also like to know, For the Processor's and Chipsets 's does Intel Provide IBIS models?
Hello Syed,
We are working the issue in case 03228609; and this was escalate. I will add you new inquiry to the case so they can also provide you information about it.
regards,
Jeremiah A.
Jeremiah,
We hank you for Your Extended Support. Its Been Over a month since the Query has been raised.
We Would highly appreciate is you could have this resolved at the earliest.
Kindly let me know the details requires and i shall have them shared.
Hello Syed,
We are working this issue in case 03228609, and the case was escalated. I added you new inquiry to the case so they can also provide you information about it. They will contact you as soon as possible.
regards,
Jeremiah A.
