Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4923 Discussions
IPMI Query not working on newer BMC ?
SDiem
On the new Servers we could not query with IPMI the new BMC.
ipmiutil.exe sel -N <IP or Name of the BMC> -U username -P password
we dont get the following :
ipmiutil sel version 3.13
Connecting to node 10.0.2.63
GetSessChallenge: Invalid data field in request
ipmilan_open_session error, rv = 0xcc
ipmilan Invalid data field in request
ipmi_open error = 204 Invalid data field in request
ipmiutil sel, Invalid data field in request
on "older" Server with older BMC this works great
Connecting to node 10.0.2.68
-- BMC version 1.48, IPMI version 2.0
SEL Ver 37 Support 07, Size = 3639 records (Used=607, Free=3032)
RecId Date/Time_______ SEV Src_ Evt_Type___ Sens# Evt_detail - Trig [Evt_data]
0001 12/05/16 10:29:57 INF BMC Event Log #07 Log Cleared 6f [02 ff ff]
Server where IPMI Quersy are working:
RMM Status :Intel(R) RMM installed
Device (BMC) Available :YesBMC FW
Build Time :Nov 26 2017 18:09:58
BIOS ID :SE5C600.86B.02.06.E006.013120181511
BMC FW Rev :01.28.11044
Boot FW Rev :01.17SDR Package Version :SDR Package 1.14
Mgmt Engine (ME) FW Rev :02.01.07.328
Servers where it not works:
Remote Management Module key :Installed
BMC Firmware Build Time :Fri Feb 1 03:41:33 2019
BIOS ID :SE5C620.86B.02.01.0008.031920191559
BMC FW Rev :1.93.870cf4f0
Backup BMC FW Rev :1.93.870cf4f0
Build ID :870CF4F0SDR
Package Version :1.93
Mgmt Engine (ME) FW Rev :04.01.04.251
Any help or suggestion will be appreciated.
Thanks in advance
Emeth_O_Intel
Hi SDiem,
Thank you for contacting Intel Server Community.
I was reviewing the details provided and according to your information, the IPMI Tool is not working on the Intel Server Board that uses the BMC Firmware Version 1.93. On the other hand, you have a different Intel Server System that uses the BMC Firmware Version 1.48 and the IPMITool works accordingly.
Cipher Suite 3 is disabled by default since BMC firmware 1.90 and only keep Cipher Suite 17 opened by default. Due to this, the extra parameter "-C 17" is required for ipmitool to work via LAN.
  1. Could you please try the above parameter to make sure of this configuration?
  2. Also, I was reviewing the outputs provided and I noticed you are using the different versions of the IPMI Tool. On the system that is working you use version 2.0 but on the other system that is not working you use version 3.13. By any chance, have you tried to use version 2.0 in the new implementation just for testing porpuses?
It will be very important for me to analyze the Sysinfo Logs from both Intel Server Systems to verify some extra details.
Try to extract the Logs using the Intel System Information Retrieval Utility. Please, check the link below to use the tool for collecting system information:
https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html
I will be waiting for your response in order to proceed with the next step.
Have a wonderful day.
Emeth O.
A Contingent Worker at Intel
Emeth_O_Intel
Hi SDiem,
Emeth O.
Emeth_O_Intel
Hello SDiem,
I am following up on your case in order to verify if you still need help with this. If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
SDiem
Hi Emeth
Thank you very much for the reply. ipmitool and the extra parameter "-C 17" the query works as expected.
Do i missed something in the release notes ? or where is this documented ?
Once again. Thank you, you helped me a lot.
Greetings
Emeth_O_Intel
Hi SDiem,
I found the information on the following link:
https://downloadmirror.intel.com/29106/eng/Release%20Notes%20BMC%202.22.59c3b83a.txt
Is there anything else I can with you with? If so please let me know and I will be more than happy to assist you.
Emeth O.
