PCIe spec defined 3 types of AtomicOps transactions:
"AtomicOps are architected for device-to-host, device-to-device, and host-to-device transactions."
If Intel® Xeon® Processor Scalable Family support Pcie AtomicOps host-to-device transactions? The background for this question is it looks in previous Xeon generation, only PCIe AtomicOps device-to-host transactions are supported: "The Intel Xeon processor E7 V2 family supports PCIe atomic operations (as a completer)". Not sure if Scalable family extend the support to host-to-device using X86 ISA based instructions?
I was reviewing the information that you are looking for about the support of the Atomic Operations on the Intel® Xeon® Processor Scalable Family.
Let me make sure those details in order to provide you the most accurate information about it and as soon as I have an outcome of this, I will let you know all the information.
Emeth O
Thanks for the quick response. Yes. I am looking for details on Scalable Family Processor PCIe atomic operators support, especially on host-to-device transactions support.
Let me know if any answer available.
Thank you so much for been so patience.
I would like to share with you the list of processor families that support AtomicOps:
1. E7 V2
2. E5 2600 v2
3. E7 8800/4800 V3
Therefore Scalable Family does not.
If you have any other question let me know and I will be more than happy to assist you.
Emeth O
Hi Emeth,
Thanks for your response.
Previously I just want to check if Intel® Xeon® Processor Scalable Family support PCIe AtomicOps host-to-device transactions or not. My assumption is Xeon scalable family have supported PCIe AtomicOps device-to-host transactions already.
Now I am a little confused about your answer. Could please double check and confirm that Intel® Xeon® Processor Scalable Family did not support any PCIe AtomicOps transactions, even for device-to-host (RC as completer) transactions?
Minfeng
I would like to inform you that according to the information provided, the Intel® Xeon® Processor Scalable Family does not support the AtomicOps. Only the following processors:
1. E7 V2
2. E5 2600 v2
3. E7 8800/4800 V3
Emeth O.
Thanks. Just one more question:
However, In https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xeon-e5-v4-datasheet-vol-2.pdf https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xeon-e5-v4-datasheet-vol-2.pdf Page 132, register description about devcap2 (PCI Express Device Capabilities 2 Register)
The default value from atomic128bcascompsup, atomic64bcompsup, atomic32bcompsup (bit 9, 8 , 7) is "1" - According to PCIe spec, that means RC completer AtomicOps should be supported.
If that means E5 V4 also support PCIe RC completer AtomicOps?
Hello kmf,
I completely understood your point; however, the information provided is coming from the engineer the department. So, according to them the only processors that support the AtomicOps are the processors mentioned before.
Emeth O.
