Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4502 Discussions
In CRPS power supply document 573090, MFR_MAX_IOUT_CAPABILITY
chunfung
In CRPS power supply document 573090, it listed details about the new "MFR_MAX_IOUT_CAPABILITY" PMbus command.
The Ipeak.max duration value unit should be "ms" or "micro second"?
In document 610445 Eagle stream power supply recommendations, it is using "micro seconds" for Ipeak.max duration.
In CRPS power supply document 573090, it is using "milli seconds" for Ipeak.max duration.
Which is correct?
SergioS_Intel
Hello chunfung,
Thank you for contacting Intel Customer Support.
Please allow us to check in your question and we will get back to you as soon as possible.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Intel-ScottH
I confirmed with 610445 document, and CRPS owner.
The 610445 is correct, the Ipeak.max duration magnitude is micro-second. the CRPS has a typo.
