Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
In the Sawtooth Pass Refresh S2600STBR, how do I change the speed settings of the X722 network adapters? I need to slow this 10BaseT network port down from 10 GbE to 100Mbps for my office LAN.
jBart26
Table 12 on page 64 of https://www.intel.com/content/dam/support/us/en/documents/server-products/Intel_S2600ST_TPS.pdf, showsthe lowest supported data rate is defined as 100 Mbps, which shows it can be done. How?
jBart26
Rather, I need to change to 100 Mbps for a customer, and the only options
under Properties | select port | Properties | Advanced \ Speed & Duplex are
[Auto Negotiation], [1.0 Gbps Full Duplex], and [10 Gbps Full Duplex].
jBart26
Note: These are the onboard adapters on the motherboard.
jBart26
OS in use: WIn10x64 Enterprise RS5-1809.
SBlitz
New Contributor II
Using Intel Proset in Windows can help you fix the speed
jBart26
I ran Intel PROset which advised it could not alter the port configurations on the S2600STBR.
jBart26
"ADAPTER NOT SUPPORTED
This device cannot be configured by Intel PROSet Adapter Configuration Utility. Use the Intel PROSet Module for Windows Powershell interface or Windows Device Manager to configure the device. Consult the user guide for more information."
Windows Device Manager was not able to change port speed, FYI.
jBart26
jBart26
The latest version I can find for the LAN drivers for the Sawtooth Pass Refresh motherboard, version 24.2, does not include any PowerShell Commandlets, either.
