I would simply like to know if it is possible to Install an OS on an Intel S2600CW motherboard's M.2/NGFF slot's drive. If it is, what options do I need to enable in the BIOS for the OS installation to see the drive as an installation destination?
Hello Some user,
In regards to your question, you only need to connect the M.2 drive to your system, there is no need to setup any BIOS option. Just make sure to select the M.2 drive during the bootup process
Please take in consideration that once M.2/NGFF device is used on the server board, SATA - 4 port cannot be used. SATA - 5 can be used at the same time when M.2/NGFF device is used, also remember the S2600CW Server Board only supports the SATA interface (AHCI). Even when M.2/NGFF allows support for many different interfaces, PCIe, USB, or any interface different than SATA, is not supported.
You can find more information checking the technical product specification http://download.intel.com/support/motherboards/server/s2600cw/sb/s2600cw_tps_r1_3.pdf here, page 39.
Regards.
Thanks for the reply. I will need to investigate further as it seems the drive (Samsung NVMe SSD 960 PRO 1TB) does not get detected by the BIOS. I have upgraded to the latest BIOS version (01010021) without the drive showing up. Any thoughts as why this could be?
I had a look, seems like the motherboard only allows for M.2 SATA mode where the Samsung 960 Pro uses a PCIe 3.0 interface.
Hello Some,
Please take in consideration that although M.2/NGFF allows support for many different interfaces, this server board supports
only the SATA interface (all other interfaces such as PCIe and USB are not supported).
After checking this Intel server configuration https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&dynamicUser=Y&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 tool we found a list of test M.2 devices for your system:
Vendor Part number Description MicronSSD-SATA-M.2MTFDDAV1T9TBY-1AR16ABYYMTFDDAV1T9TBY-1AR16ABYY (1.92TB, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV1T9TBY-1AR1ZABYYMTFDDAV1T9TBY-1AR1ZABYY (1.92TB, M.2, 80mm, SATA)MicronSSD-SATA-M.2MTFDDAV1T9TCB-1AR16ABYYMTFDDAV1T9TCB-1AR16ABYY (1.92TB, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV240TCB-1AR16ABYYMTFDDAV240TCB-1AR16ABYY (240GB, 6Gb/s, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV480TBY-1AR16ABYYMTFDDAV480TBY-1AR16ABYY (480GB, 6Gb/s, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV480TBY-1AR1ZABYYMTFDDAV480TBY-1AR1ZABYY (480GB, 6Gb/s, M.2, 80mm, SATA)MicronSSD-SATA-M.2MTFDDAV480TCB-1AR16ABYYMTFDDAV480TCB-1AR16ABYY (480GB, 6Gb/s, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV960TBY-1AR16ABYYMTFDDAV960TBY-1AR16ABYY (960GB, M.2, 80mm, SATA, Encrypted)MicronSSD-SATA-M.2MTFDDAV960TBY-1AR1ZABYYMTFDDAV960TBY-1AR1ZABYY (960GB, M.2, 80mm, SATA)MicronSSD-SATA-M.2MTFDDAV960TCB-1AR16ABYYMTFDDAV960TCB-1AR16ABYY (960GB, M.2, 80mm, SATA, Encrypted)IntelSSD-SATA-M.2SSDSCKJB150G701SSDSCKJB150G701 (150GB, 6Gb/s, M.2 80mm, SATA, 3D1)IntelSSD-SATA-M.2SSDSCKJB240G701SSDSCKJB240G701 (240GB, 6Gb/s, M.2, 80mm, SATA, 3D1, MLC)IntelSSD-SATA-M.2SSDSCKJB480G701SSDSCKJB480G701 (480GB, 6Gb/s, M.2 80mm SATA, 3D1, MLC)IntelSSD-SATA-M.2SSDSCKJB760G701SSDSCKJB760G701 (760GB, 6Gb/s, M.2, 80mm, SATA, 3D1, MLC)
Sergio S.
Hello Some user,
We are following up your case and we would like to know if you need further assistance with your support request.
Sergio S.
Hello Some User,
This message is to let you know that we are closing this case, in case you need more assistance please contact us back.
Regards.
