Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Installing 2008 r2 on s5500hcv
DLegg
Hi all,
I am having an issue installing 2008/r2 on a s5500hcv server using a gpt drive.
I have updated the mainboard firmware to 64, and the raid card as well (rs2bl040).
I have seperated the VD's two one 6tb, and one 2tb. The 2tb is for the backup staging, so i cannot use that
I have a uefi boot USB, which allows the install to load, i can select the OS, and choose the disk, it creates the partitions and then click on next, and it sits at Copying Windows files (0%) for as long as you want to leave it, It wont progress past 0%.
I have tried all different bios settings, and other suggestions that i have seen whilst researching the issue, all of which come to a grinding halt.
Can anyone suggest a way to get it to work
thanks
Dan
David_A_Intel
I would recommend following our http://www.intel.com/support/motherboards/server/sb/CS-031158 GPT White Paper. You may want to check the section for Plan B as you already have your RAID configuration created.
You mentioned that the installation hangs at 0% Copying Files. Have you tried to use different media? You may want to try the installation with a non-EFI configuration to compare results.
DLegg
I have tried using the White paper, and no result, still stops at copying windows files.
I have been able to install using non gpt/uefi setup, but i need the storage on the drive as it will be used as a hyper-v host/ backup dc.
I have partitioned the drive to be 800gb primary (os) drive and 5tb storage if it helps.
Another thing I noticed, whenever I click to start the copy, the mouse locks up. Not sure if it's relevant or not.
As for installation media, I have tried both 2008 & 2008 r2, on both own cd, and USB, I have also tried via mdt, but no luck so far
DLegg
In addition to this, i have just tried to use Hyper-V Server 2012, and it has the same result. Im going to try a different RAID card next. I'll post up how it goes.
