Server Products
4784 Discussions
Intel 1200 BTL beep tones
HSchl
I have an Intel 1200BTL motherboard with Xeon E3-1200v2 processor which sadly started beeping a few hours ago during boot. It beeps shortly six times and then remains silent. I'm not sure though if the beeps come from the BIOS or BMC. I guess it should be the BMC since in this case the beep sequence is supposed to happen only one time whereas the BIOS beep sequence should repeat itself. Also iirc from some earlier failures the BIOS sequence has a higher pitched noise compared to the current sequence.
The https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf manual was not really helpful and I also could not find much for six beep tones on the web. For the AMI BIOS it would mean some A20 gate failure which is not really helpful.https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf But as said, I don't even know if it is the BIOS. I also don't know if the error is related to the mainboard or maybe to the processor. I already changed the RAM so I guess I can exclude that. Any help appreciated.
Hello fl1,
Hope you are doing fine.
In order to solve that issue, we would need to play around with the server.
Does the server post?
Did you try to clear the c/mos?
Do you have any USB connected?
Charlie_Intel
Hello fl1,
We are wondering if you need further assistance?
Charlie_Intel
Hello fl1,
We are wondering if you have further questions or if we are able to close this thread?
Charlie_Intel
